Ir para o conteúdo principal
Repair guides and disassembly information for the 16-inch MacBook Pro released in October of 2021, featuring Apple-designed M1 Pro and M1 Max SoCs. Model A2485.
68 Perguntas Visualizar todos
What screws attach the bottom panel of the 2021 MacBook Pro (A2485)?
I am trying to identify exactly what screws Apple is using to attach the bottom panel of the 2021 MacBook Pro 16” (A2485). There are 8 screws in total. Any help is very much appreciated. Thanks!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
@mw747 Here is part of the screw chart for the ones that Apple is using. Of course, nothing is ever easy.
923-06868 for the front and 923-06869 for the back if you are using the space grey :)
Esta resposta foi útil?
Pontuação 1
9 comentários:
Hi, where would I be able to get these screws?
por
I'm also looking for these screws :/ More specifically, the 923-06869 ones.
por
Yeah, I want to know the different size screws for a MacBook Pro 2020? It has 8 screws, but I need to see the sizes for just the back cover. I'm surprised this is not on the web.
por
@elainefargo the back cover or do you mean the bottom cover? what model is your MBP?
por
Oh, I meant the bottom cover. I may have used screws from my other laptop, MacBook Air and if so I need to swap them out. I spilled water on the MacBook Air because the water bottle was warped with a rounded bottom from the store. I wiped it and put it in brown rice, covered. After 2 months it works perfectly again but brown rice got inside. I shook it and a lot of brown rice came out the top even out some keys. But as I was using it I could hear a slight version of a couple popcorns piping, but not as loud and not a lot. So, I took the bottom cover off there wet three rices and I let them fall of, but as I shake it, it still sounds like there is some rice under the place on the other side of the mother board.
por
Exibir mais 4 comentários
Adicionar a sua resposta
Michael Waite será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 10
Últimos 30 dias: 94
Duração total: 1,417
