Probable short circuit on a iPad Air 2
Hi guys, I need an advice from an iPad repair tech. Got a Air 2 that doesn’t power up, no sign of activity. When I connect the charger I get 4.5v and 2.5amps on the usb tester. There probably a short somewhere. The iPad is not open yet, I checked the charging port under microscope and it seem perfect. So where could be the short inside ? Thanks, any help is appreciate :-)
Esta pergunta é pertinente?
If there was a short on power rails I don’t think you would get a draw of 2.5a through the charging port it would usually be 0a. Have you tried connecting to a pc with iTunes to see if it’s recognised.
por daniel
Yes, still no activity connected to a Mac and nothing on iTunes. Could it be a short in the lightning port ? Thanks Daniel
por lemerise
