Ir para o conteúdo principal
Versão atualizada do MacBook Retina de 2016. Modelo A1534, EMC 3099. Agora equipado com processadores Kaby Lake mais rápidos, até Core i7 de 1,4 GHz com Turbo Boost de até 3,6 GHz e SSD até 50 % mais rápido, além de suportar até o dobro da memória.
Display error - lines on right side
Hey guys,
I plan on buying a used MacBook 2017 Retina. The picture shows, that it has a display error on the right hand side. As I will mainly use it with external displays attached, I don’t worry too much about it, but would like to know, if this is a common problem that is easily fixable or a bigger problem that needs a fix from apple?
Thank you all for your help,
Stefan
Hallo Leute,
ich habe vor mir ein gebrauchtes MacBook 2017 Retina zu kaufen. Auf den Bildern sieht man, dass es einen Displayfehler auf der rechten Seite hat. Da ich es hauptsächlich über externe Monitore betreiben werde, stört mich das nicht allzu sehr, aber ich würde gerne wissen, ob dies ein bekanntes, leicht zu behebendes Problem ist, oder aber etwas schwerwiegendes, was eine Reparatur von Apple benötigt.
Danke für eure Hilfe,
Stefan
Imagem
Imagem
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Pergunta mais útil
The LCD panel in the lid got damaged. Likely along the edge so som e of the lines got severed. Sadly this will require a new display assembly MacBook 12" Retina (Early 2015-2017) Display Assembly iFixit only has the Rose Gold in stock. Here’s the guide to put it in Substituição do conjunto do display do MacBook Retina 2017
Here’s a run down on the Apple P/N’s for the different units:
  • Gold - 661-02248
  • Space Grey - 661-02266
  • Rose Gold - 661-04852
  • Silver - 661-06786
Imagem de Replace a display compatible with the early 2015 to 2017 model A1534 12" Retina MacBook laptop. Includes the 2304 x 1440 pixel 12" LCD screen, aluminum case, 480p Facetime webcam camera.
Produto
$584.99
Esta resposta foi útil?
Pontuação 1
7 comentários:
Sadly there are no replacements available for Germany. Any idea where I can source one that ships to Germany?
por Compartilhar
@narunac Which one? Silver, Space Grey, Gold or Rose Gold?
por Compartilhar
Sorry. Rose gold.
por Compartilhar
@narunac - Sorry it appears they are hard to come by right now. Give these folks a call TheBookYard Reference the part number.
por Compartilhar
true, i would recommend finding a donor laptop of the same kind MAKE SURE THE SELLER SAYS THE SCREEN WORKS, then transfer it to the laptop
por Compartilhar
Exibir mais 2 comentários
Adicionar a sua resposta
Stefan Teucher será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 24
Ao todo: 469
