Ir para o conteúdo principal
8-inch extended range low frequency driver1-inch (25 mm) compression driver200 watts of output powerMic/Line input with Volume control and Clip LED1 3/8-inch (35 mm) Pole mount receptacleFloor monitor positioning optionsSpeaker Type: Active PA Speakers
1 Perguntas Visualizar todos
Speaker not working and just clicking
My speaker has been doing this for a while now. there is no power light when I switch it on (or any light at all) and it makes this high pitched noise and then goes on making a beat that is prob 60hz subdivided by 4 beats. (the speaker is a samson auro d208)
Esta é uma boa pergunta?
Pontuação 1
2 comentários
Sir samson auro 208 spikar hai power aa raha hai but spikar nahi chal raha hai ic gya hai new cad milega
por
Card mangana hai cantect number dijiye
por
Adicionar um comentário
2 respostas
Solução escolhida
Hi @mcofficalplays ,
Here’s the schematic for the speaker.
This will help you to find out why there is no power light for a start.
Esta resposta foi útil?
Pontuação 1
Check your pcb dsp replace and place again... It Will be solve the problem
Pontuação 0
Adicionar a sua resposta
McOfficialPlayYT será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Duração total: 261
