Ir para o conteúdo principal
Model A1419 / EMC 2806 / Late 2014 or Mid 2015. 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (ID iMac15,1); EMC 2834 late 2015 / 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (iMac17,1) All with Retina 5K displays
Hard Drive failure iMac please help
EMC number: EMC 2834
  • I know enough to know enough, and thats not much.
  • My iMac crashed randomly after upgrading from High Sierra. I can boot into recovery mode but not safe mode.
In recovery mode it shows no drive to restart, back up from my time machine, etc. I ran Disk-aid and everything says its fine. If I go to wipe it, it states error can’t write last sector. If I hook it to another iMac and boot it into drive mode it shows only the 128g drive.
Thus, it’s safe to assume the Hard Drive has failed in my Fusion Drive set that failed ??
I can’t seem to find a straight answer online, some places say its impossible to work on the drive, etc.
A - Is there anything else a novice can do, i’ve accepted the drive is toast but i’m surprised I can’t do anything other than just replace it.
B - Is my model capable of me just replacing the hard drive?
C - I just ordered a new iMac, so I don’t need a $600 3 TB SSD replacement drive, i’m fine putting in a standard drive.
D - My iFixit tool kit just arrived
E - What drive works in this computer,
F - What glue, gasket, heat tape etc kit do I need.
My dad was a computer programmer for Apple for years, I know the lingo to a degree and have enough confidence to crack the Mac open. What I lack is the knowledge to order the right parts and decipher all the forums, info etc.
Esta é uma boa pergunta?
Pontuação 1
1 comentário
Ok, lots of info.
A- After i put in the new drive ill just install Mojave to remove the need the extra cost of the sensor. I have a jump drive i will use and create a boot disk that way.
B-ill just buy a 2-3tb hard drive and call it good, this will just be my back up desktop for my kids to use.
C- Items i will need
C1- cardboard service wedge
C2-adhesive strips with tool
C3- what type of hard drive do you recommend? i have never had a hard drive in any of my macs in 21 years ever go bad, this is the first (my iMac that is 3 years older than this one being discussed still has the original drive)
por
Adicionar um comentário
3 respostas
Solução escolhida
Hi
I’m sorry to hear about your iMac hopefully my answer can help
I’ve done a little research and it doesn’t seem like you cant just replace the hdd part of a fusion drive however I would replace the fusion drive with a solid state drive made by intel,Toshiba or Samsung because as far as I know ssd’s are faster that fusion drives
If you do want to replace it
Here is a video link that give a rough idea of what you have to do https://youtu.be/1YO46G5rifM
As for doing the replacement ifixit probably has a tutorial on it
Ps if you do replace it please be careful of the exposed power supply as they are extremely dangerous if touched
Any questions please ask
Esta resposta foi útil?
Pontuação 1
2 comentários:
even after its unplugged ?
por
Yes even after unplugged
The capacitors stay charged for a very long time
por
Well the good news is you can fix your system!
Lets review what a Fusion Drive is as it often confuses people! It is two physical drives, a HDD which is the main drive and a small SSD which is strictly a cache drive. Both your systems ports HDD - SATA connection & SSD - NVMe/PCIe slot are used.
The HDD holds ALL of your data! The SSD is like a pony express way station offering a fresh horse for the rest of the run. Here the Cache Drive holds more frequently requested data blocks (that fresh Horse) but the alteration of these data blocks are written back the the HDD.
But lets look a bit deeper what are these blocks?? You just started your system so what’s being loaded the OS and if you have already enable auto load of anything that too will be grabbed from the drive. Depending on the size of the cache drive (Apple offered a few different sizes across the different models) once the drive is full thats what is held. Now most of this stuff is not getting altered, but if you don’t auto load then the application you use and its data is more likely to be loaded. Lets say its your 100+ page essay your history teacher is expecting! Well that full document will be held in the cache, but as you correct and polish the document the data blocks get written back, In addition Apple was smart always writing back every so often and lastly iCloud if you have it enabled!
OK, Bang! The screen goes wacky and as you discovered the HDD died!
So the more important drive of the pair went on you so sadly the data it held is gone! But you where good! You backed up often as you knew HDD’s wear out!
Now the tricky part replacing the HDD. Frankly its not overly hard to do! Substituição do disco rígido do iMac Intel 27" com tela Retina 5K iFixit offers a kit with all of the needed stuff! Or you can replace your drive as you want maybe you want another HDD larger maybe or you want a different vendors drive than what Apple used. You’ll need the iMac Intel 27" (2012-2019) Adhesive Strips and the tool that comes with it BEFORE you start. Unless you have some cardboard to make your own wedge you might as well get this iMac Intel 27" Cardboard Service Wedge.
OK what about that sensor thing?? iMac Intel 21.5" and 27" (Late 2012-Early 2019) SSD Temperature Sensor You didn’t tell us which macOS you upgraded to. The reason why this would be helpful is Mojave and newer now use the newer S.M.A.R.T. method of temperature monitoring, you see your systems heat management system (SMC) requires access to the drives sensor and of course Apple contracted for a custom HDD so the internal sensor is exposed for their SMC services. 3rd party drives don’t offer this modification so SMC goes crazy! Slowing your systems CPU clocking to a crawl and ramping up the Fans RPM to protect your system, To be safe I would put it in.
Now the last install issue If you are replacing the drive for a 2.5” unit you’ll need an adapter frame.
But… What about that cache drive?? You’ll need to wipe it down if you want to create the Fusion Drive again. Remember this only works effectively with a HDD as its mate! Frankly if you want to push your system to the max I would replace the small cache drive with something bigger like 512 GB or 1 TB and making it the boot drive. Here’s the guide iMac Intel 27" Retina 5K Display Blade SSD Replacement
Consider just going with the blade drive pulling both Fusion Drive set drives!
Imagem de This custom fit wedge supports your iMac display during repairs.
Produto
Imagem de Add an SSD to your iMac with this cable. A temperature sensor for the SSD is included.
Produto
$39.99
Imagem de These replacement foam adhesive strips secure the display compatible with the A1419 model 2012, 2013, 2014, 2015, 2017, and 2019 27 inch iMac and the A1862 iMac Pro.  EMC 2546, 2639, 2806, 2834, 3070, 3194, 3144.
Produto
$19.99
Imagem de iMac Intel 27" Retina 5K Display Disco rígido
Guia
Nível de dificuldade:
Moderado
1 - 2 hours
Imagem de iMac Intel 27" Retina 5K Display Blade SSD
Guia
Difícil
2 hours
Pontuação 1
Hi Dan, I have the same issue as the OP and had a followup question to your very informative post. Instead of upgrading the blade drive to replace the Fusion Drive set (HDD+Blade), is it possible to just install the HDD with an SSD and somehow disable the use of the blade drive cache? I'm sure an SSD boot drive will be more than enough for me, and it is much easier from what I can tell, to upgrade the HDD than it is the blade drive.
Pontuação 0
1 comentário:
Andrew - Apple has altered things a few times at first you could break the Fusion Drive set now you can’t and for a while having the Caching drive in place didn’t matter. With the newer OS’s it gets in the way so I recommend pulling it.
If you want a dual drive setup (which I think is the better direction) then you will need to replace the small caching drive to something useful. As I stated I would go with at a minimum a 512GB drive and ideally go with a 1TB drive. To be clear we are swapping the blade drive out, the SATA HDD is still present.
Here we are then formatting bigger blade drive as the booting OS drive and then copying over your apps, then delete the HDD copy of the apps (make sure you have a good backup first).
If your question was to swap out the SATA HDD for a SSD that also works, but it’s slower than the NVMe/PCIe interface the blade drive uses.
por
Adicionar a sua resposta
Sean será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 14
Ao todo: 1,866
