Hi,
I just have the same probleme after take a bath with headphone (dont do that haha !)
After it the headphone cant charge.
Just charge and stop
Usually about fixing item, I tried to fix it.
so basically for find the charger plug inside :
You can follow the tutorial for see the battery.
In additional you must remove the big flex cable (blue and white) its plug in to the usb c card.
After you need to take off all screw inside ear. there is 11 screws. When its finish you can use the plastic blue tool and pull to yourself the black plastic inside. Dont pull too much because the ear is welded to a black cable. But you could access enough to the usb card.
So when u see it just take off the screw and pull the card to you (you can help the flex from the other side).
After you can replace it, or clean it. (Brush it).
In my case the heaphone dont charging, after pulg it the red light stay only 5 seconde and stop.
I have the card in front of me now and the connexion are a bit blued (because water)
I m done it was enough to brush it. But dont forget to inspect the flex cable, it was hit too.
Now its charging.
I just brush (teeth or nails brush is good) + alcohol.
If its impossible. You can find parts « the usb c board » (but hard) on e ba y
3 comentários
Hi,
Post some close up images in your question to show the extent of the corrosion. Here’s how to do this on ifixit Adicionar imagens a uma pergunta já existente.
With corrosion, initially try to remove the surface corrosion using a clean cloth dampened with vinegar. Not dripping wet. Use a clean part of the cloth with every wipe over of the cloth.
Also ensure that the battery is disconnected when working on the device.
Once it has been cleaned you can check the contact surface to see what damage has occurred and what might be able to be done to fix it.
por jayeff
It's about hard to get a picture it's inside the connection according to the Sony or whoever jb-hifi send them off to for repair. From the outside everything looks good as new
por tim conibear
Exactly the same problem. SONY SHOULD HAVE WARNED about corrosion from charging port if wore often and swept. they should repair under guarantee. they did not do it with mine. This is the second pair with same problem. DO NOT BUY THEM
por IsaNP
