Ir para o conteúdo principal
Repair guides and support for Lenovo's line of consumer-oriented laptops, the IdeaPad series, first announced January 2008.
1094 Perguntas Visualizar todos
Weird clicking sound after trying to open laptop
Hey everyone, I ordered a Lenovo Ideapad Gaming 3 a couple of weeks ago, and it arrived last week. I’ve been wanting to upgrade the RAM to 16GB, so I decided to open it up for the first time. I’ve never opened a laptop before, and I did not open it successfully. The areas with the hinges were giving me a hard time so I told myself that I would open it later in the day. I think I closed it properly (I heard the clicks) and turned the laptop back on. As soon as I pressed my Q key, the laptop made a loud sound and from then on, there was a faint clicking noise every couple of seconds.
The noise sounded like a key being pressed, and it is near my left hinge and Q key. I think that my trying to open up the hinge area messed something up and now I don’t know how to fix it.
If anyone has any solutions to my problem, please let me know. Any help is appreciated :)
Edit: I confirmed that the cause of the sound is the fan. I think that while trying to open the laptop, I might have moved the fan somehow.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
3 respostas
Pergunta mais útil
@porgdotorg time to open it up properly and replace the fan. At least check out what went wrong. Download the service manual from here Page 36 will show you how to get to the fan
Esta resposta foi útil?
Pontuação 1
3 comentários:
does the fan have to be replaced?
por
@porgdotorg maybe or maybe not. It depends what you find once you open it up. It is possible that it is deformed and the fan-blade hitting the fan case. See what you find.
por
@oldturkey03
Could possibly just be a wire or something on the case close to the fan blades. Have had that one a number of times.
por
Try opening it again and make sure everything is on the right place
Pontuação 0
2 comentários:
will this void my warranty?
por
@porgdotorg
Probably. Read the terms of the warranty.
por
I've got the same laptop, the fans start every 2 seconds, rotate for about 1 second then stop. This is the clicking noise you might be hearing. I think it's normal.
Pontuação 0
Adicionar a sua resposta
Porg será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 17
Duração total: 758
