Ir para o conteúdo principal
Repair information for the things you might find in around the yard or patio, including BBQ grills and equipment, gardening tools, and weather stations.
20 Perguntas Visualizar todos
Engine shuts off when making a left or right turn
So I have a areator with a Honda GX120 for the motor. The engine will idle and run, I can go in a straight line but when I have to turn either direction it shuts off. It looses all spark I don't know what could cause the issue
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
@travis78 check all the wiring. Make sure that they are all properly connected. Also check for any wiring that may be rubbing against the frame of this as well as the stop/kill switch. It definitely sounds like something is shortening out.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Travis será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 67
