Ir para o conteúdo principal
Repair for speakers, stereos, header units, and CD players for your car or truck.
I have 2012 Toyota Camry the audio system w9rk but no sound
I have problems with my Camry audio system work but no sound
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
Hi,
Is the audio unit a stock Camry unit or an after market head unit?
por
Adicionar um comentário
1 resposta
If your Camry has the factory radio, it might be either the head unit (in the dash) or a separate amplifier module (mounted somewhere else) that has failed. A competent car audio shop can diagnose the problem. If the factory amp module is bad, there are kits specifically to replace the amp and retain your factory head unit if that is what you'd prefer. A Toyota dealer can also help troubleshoot but the dealer will be much more expensive than taking the car to a car audio shop. There are aftermarket solutions that allow you to keep as much or as little of the factory equipment as you want.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Irene Mcdonald será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 9
Ao todo: 96
