Ir para o conteúdo principal
O HP Elitebook x360 1030 G2 é um dispositivo 2 em 1 que funciona como laptop e tablet. Esta página contém guias de reparo, informações de manutenção e serviço, além de um manual de resolução de problemas relacionado ao HP Elitebook x360 1030 G2. Número do modelo da bateria: 1GY30PA
Is the RAM upgradeable?
I wanted to upgrade the RAM, but I can’t find it in the laptop. Is it on the MB?
Esta é uma boa pergunta?
Pontuação 0
2 comentários
i want to upgrade my hp g2 ram it is 8 GB and i want to make it 16 GB so how can you help me with? I usually not meet some softwares requirement what should i do
por Compartilhar
@goodlucknelson Check the answers. The short answer is that you can't. The RAM is soldered onto the board, making it a extremely difficult replacement process. Not impossible, just not worth the risks.
por Compartilhar
Adicionar um comentário
3 respostas
Solução escolhida
HPs documentation indicates that the RAM on this model is soldered onto the board. So for all intents and purposes, no it is not user upgradeable.
Esta resposta foi útil?
Pontuação 4
2 comentários:
What if the RAM fail? My computer RAM Failed but not removable
por Compartilhar
@Biruk Ayele You might be able to find a repair technician who does board level repairs that can diagnose the issue and replace either the RAM chips themselves, or whatever faulty component is causing the problem.
Otherwise you'll have to replace the system board to restore functionality.
por Compartilhar
This seems to be factory configured
“About your EliteBook x360 1030 G2
Your computer's memory capability:
Standard memory:
4GB to 16GB non-removable”
Pontuação 1
2 comentários:
"The HP EliteBook x360 1030 G2 comes with 8GB DDR4 RAM on board, and there is no spare RAM slot, so you can not upgrade the RAM."
por Compartilhar
HP EliteBook x360 1030 G2 Disassembly (SSD, RAM Upgrade Options)
A pretty detailed tear down https://www.laptopmain.com/hp-elitebook-...
por Compartilhar
Nope, it's on the MB.
Pontuação 0
Adicionar a sua resposta
Richard J será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 12
Últimos 30 dias: 85
Ao todo: 11,832
