Trying to locate the location on the water inlet valve.
I am trying to locate the location on the water inlet valve. It is not located at the rear bottom. It is a jennair model JFI2589AES
Esta é uma boa pergunta?
Hi @hbc6415,
Here’s a link that shows the location of the dual water inlet valve part #67006322 in your model. (supplier example only)
Here’s the tech sheet for the refrigerator which may also help as it shows how to run the diagnostic tests for all the components. The wiring diagram might also come in handy if it is an electrical connection problem
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Ao todo: 97
