Ir para o conteúdo principal
Guides for the Wi-Fi version of the iPad mini 5—model A2133. Released in March 2019, the iPad mini 5 is the successor to the iPad mini 4.
9 Perguntas Visualizar todos
Kids put the iPad in the microwave and now it has lines
Kids put the iPad in the microwave and now it has lines across the screen. so how do I know if I need to replace only the iPad screen digitizer or the LCD or both?
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Oh man, that's rough! I can only imagine how frustrating that must've been for you.
por
Adicionar um comentário
2 respostas
Solução escolhida
To fix this problem, you will need to get a new screen. Follow the guide here to replace the screen.
On some iPad models, the screen and digitizer are seperate parts. However, on this iPad model, the LCD and digitizer are fused together, meaning that if one of the parts fails, you need to replace them both.
Imagem de iPad mini 5 Screen
Produto
iPad mini 5 Screen
$149.99
Esta resposta foi útil?
Pontuação 2
Pergunta mais útil
Hi @adamipad,
Microwaves wouldn't have done the logic board much good either.
You may have to start by temporarily replacing the display assembly to find out if the problem is isolated to it or the logic board or both.
Here’s the ifixit iPad mini 5 Wi-Fi Screen Replacement guide that may help
Pontuação 2
Adicionar a sua resposta
adam será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 12
Duração total: 188
