Ir para o conteúdo principal
Apple Watch Series 2, announced September 7th, 2016 and released September 16 2016.
20 Perguntas Visualizar todos
How to reseal the Apple Watch screen?
My battery got swollen and pop-ed off the screen. Note that it’s just the actual screen that detached and not the part where force touch sensor is.
I don’t know how to re-seal this part, don’t see anything obvious. I replaced the battery and screen works, force touch also works.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Once you fix your problem you’re going to need some adhesive for it so stay in place and stick.
I fixit sells some in their shop
Apple Watch (38 mm) Screen Adhesive
Imagem de Replace an adhesive strip compatible with the 38 mm case Apple Watch Original model and Series 1 and 2 models.
Produto
$6.99
Esta resposta foi útil?
Pontuação 0
1 comentário:
That adhesive is made to connect the outer glass, where force touch gasket is.
That is not my case, see the photo I posted.
por
Adicionar a sua resposta
aleck será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 6
Ao todo: 259
