Ir para o conteúdo principal
Power/Sleep and Home Button Unresponsive
I have a iPod Touch 4g which has a cracked screen. I replaced it, and still didn't put it back. I attached the two wires from the screen to the iPod, and now the Power Button and touch screen are not working. I plug in my charger, and it goes to the password screen, and I can't slide it.
How can I fix this?
EDIT: The volume button also don't work :/
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
2 respostas
Pergunta mais útil
Assuming that everything worked well before, the #1 culprit for malfunctioning electronics after dis-assembly tends to be dirty or poorly seated connectors. Clean everything well with a high-content rubbing alcohol and make sure the connectors are seated fully. If that all checks out, closely inspect each of the connectors and see if a pin was damaged. Good luck and let us know what you find!
Esta resposta foi útil?
Pontuação 1
1 comentário:
I tried this, and now the display doesn't light up anymore when I plug the charger in :(
por
It is most definitely a damaged on/off, volume flex cable. There is a post elsewhere on this site.
Pontuação 0
Adicionar a sua resposta
Cytonic será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Ao todo: 1,009
