Ir para o conteúdo principal
Toyota's 7th generation pickup, but first generation of the Tacoma branded truck designed specifically for the American market. Featured brand new sheet metal, new frame, fresh suspension and three new powerful engines.
How long does it take to replace a oil dipstick o-ring?
How much time does it take to replace a dipstick O-Ring on a 1996 Toyota Tacoma?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
California Native depends on your Tacoma’s engine size, your tools and your skills. I assume you are referring to the dipstick Tube O-ring. All it should take is the removal of one bolt that holds the tube in place. Remove that bolt, then pull the tube out. Clean the seat for the tube and replace the O-ring. Should be about an hour. Again depends on engine model, accessories mounted to your Tacoma etc.
Esta resposta foi útil?
Pontuação 1
1 comentário:
Thank you for your reply.
por
Adicionar a sua resposta
California Native será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Ao todo: 431
