Worn pin is this fixable
Are burn pins fixable
Update (12/16/2021)
can this be fixable or is it garbage?
Esta é uma boa pergunta?
Yes. You can use something like the [produto vinculado ausente ou desativado: IF317-054] and draw the new trace or put a dab of solder in the trace.
Esta resposta foi útil?
Thank you but will this be able to read the games?
It should as long as the game port deck (or whatever it is called can’t think of it) is in good condition. Just make sure to scrape off any corrosion before applying.@mmusk818
alright thank you
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 13
Ao todo: 380
