My screen is black
My phone is working but the screen is black
Esta é uma boa pergunta?
Maybe consider trying to find a replacement screen or taking it to a expert to determine if the screen has become damaged somehow.
Esta resposta foi útil?
hi, I'm a technician specializing in Vn220 repair, if you find your screen blank the most common cause is the yellow belt or wire who sends info & electricity to the screen has cut off, so the first step is to replace that wire, secondary, make sure the battery is not the problem by inserting another working battery and see if it turns on,
is there any way to obtain pictures from this phone without repairing the screen? We have taken it to a phone repair shop and they cannot find this part anywhere. (According to them)
@luzer wanna help me with this phone?
@escajeda32 If you enabled USB Debugging, that would work to connect your device to your computer or use scrpy. Though the best bet would be to find another phone and swap bottom boards to see the screen to take off whatever you like.
@yifi What do you need help with?
@fixmylgexalt replying to my post from a year ago... Think I still remember???
But thanks anyway. Also, it says in your profile that you sell these parts.
I might be interested in buying...
I wanted to offer my expertise. I am a technician and have successfully repaired over 100 of these devices.
If you're experiencing a black screen, the issue could be due to one of the following:
1. Flex cable
2. PCB (printed circuit board)
3. LCD
4. Connector on the motherboard
You can find all the necessary replacement parts at primephoneusa.com, which also offers repair services.
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 22
Ao todo: 1,743
2 comentários
Might I ask what you mean by working, and what troubleshooting steps you have followed so far?
por Jacob Mehnert Compartilhar
@isaac8183999 yep, sounds like a bad screen
por oldturkey03 Compartilhar
