Ir para o conteúdo principal
Fones de ouvido sem fio com Bluetooth 5.0 que possuem uma autonomia da bateria de 3 horas.
Right earbud stopped working
The right earbud stopped playing sound.
When I place it in the charging tray though, the little LED still lights up, so I assume it is still charging.
That being said, my bet is that it’s the speaker that stopped working…
Anybody else had the same problem and was able to fix it?
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
1 resposta
Pergunta mais útil
Make sure that the contacts in the case and on the earbud are clean and are making contact with one another and make sure that your phone can see both earbuds.
Esta resposta foi útil?
Pontuação 2
1 comentário:
As I said, the both earbuds are charging when put into the tray, so the contacts aren't the problem.
Also, the left one is working just fine, so the phone doesn't seem to be the issue here.
por
Adicionar a sua resposta
Gehtsie Nixan será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 22
Ao todo: 893
