Ir para o conteúdo principal
Only power button not working but volume button working.
I dropped my phone in water and it was soaked i did what i could and got it working there was water in the screen camera and i mic was not working i kept it a few days and everything got alright except the mic and the buttons was a little glitch and hard to press so i waited a few more days and the power buttons was kind off stuck and the mic had problem and everything was fine so for the power button i sent the phone to Samsung care there they opened the phone and asked $220 for the repair i refused and kept the phone unattended for 3 months when i finally decided to change the on/off/voulme/spen charge flex cable because the powerbutton when replacing the flex cable i cleaned the mother and daughter board still the same i charge the phone till 71% but still the power is not working pls so i need help help me fix my phone.
Imagem
Imagem
Imagem
Imagem
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
The answer was found prodably due to water damage one of the capacitors was damaged for the on/off button, not to turn the phone first hold both vol up and vol down at the same time and connect it with a cable to the pc ( chargers / phones will not work only pc ) then you will enter a menue whewre you can press vol down to reboot also make sure you have the battery plugged in!
Esta resposta foi útil?
Pontuação 0
Fid you replace the power button itself or just the cable?
Pontuação 0
4 comentários:
the cable . i only replaced the flex cable not the bower button
por
What may have happened is the water corroded the contacts in the button itself. Usually not worth ripping it apart as it's pressure fitted together. Luckly they aren't expensive
por
yes, i know that but in the note 10 lite is just a piece of plastic with a hill like structure which when pressing the button form the outside collides with the button in the flex cable which i can even do with a screw driver and i don't think no i am pretty sure it is not the button problem.
check this out: https://www.maxbhi.com/power-button-oute...
por
So you are saying you can get it to work via just the ribbon? The hill structure has a conductive pad in it. if you take it off you should be able to clean it and it should work again
por
Adicionar a sua resposta
Lucky Charms será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 21
Ao todo: 3,515
