Thermal pad size For 1070 Fe
What are the sizes of the thermal pad needed for repaste for 1070 fe? Any links and measurement will help me alot. What's the best thermal compound for GPU.
Esta é uma boa pergunta?
@mrjaigaming there used to be kit available and it had these
"Narrow" thermal pad for inductors: ~1.8mm x ~27mm x ~109mm
"Wide" thermal pad for rear-side of PCB: ~2mm x ~56mm x ~109mm
as part of it. Agree with the Arctic Thermal paste.
Esta resposta foi útil?
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 32
Duração total: 1,452
1 comentário
Hey there,
Do you need to replace them? Thermal pads don't age as quickly as thermal paste does. I'm just wondering if maybe you bought a stripped card and that is why you need it.
As far as measurements go I can't find much info around the actual thickness or size you need. You can find numerous tear downs on YouTube and they might have the info.
My preferred thermal paste is Arctic MX-5. Been using it for years.
https://www.arctic.de/us/MX-5/ACTCP00047...
por Lee Cooper
