Can it be used for CPAP
Can it be used for CPAP.
Esta é uma boa pergunta?
Tomasz Kosierkiewicz no you cannot. The pressures delivered through BiPAP are different since it requires two separate pressures(IPAP and EPAP), whereas a CPAP does not have those and you cannot turn that off. If you feel your BiPAP is not working for you talk to your HCP for a different approach. Also, check your Respironics model number and make sure it is NOT involved in the recent recall. Check on here https://philipsrecalls.com/ Do not use it until you are sure that it is safe. Again, contact your HCP for assistance with this.
Esta resposta foi útil?
we legally can not give advice for medical equipment
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 8
Duração total: 145
