Ir para o conteúdo principal
Guias de reparo, manuais e ajuda na resolução de problemas para Xbox 360. Aqui você recebe tudo o que precisa para consertar por conta própria o seu Xbox 360.
My Xbox has Heat Problems
Hi,
my xbox has a problem with overheat. When i play on this console it will after 10 minutes overheat and the console turn automatically off. When I restart come the advice that the console overheat Also is the console very loud. My question is how i can fix this problem.
Thanks for fast questions
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Pergunta mais útil
Archer,
The first thing I would do is clean the machine. Open the case and dig in to the internals using this guide and blast everything with compressed air. Once you are sure that everything is nice and clean, re-assemble and be sure that where-ever you place your xbox, it has sufficient ventilation (IE it's not in some small cabinet or on carpet). You may also consider some sort of external cooling fan and/or setting the xbox so it's standing with the CD drive vertical to give more cooling surface area.
Esta resposta foi útil?
Pontuação 3
2 comentários:
Thanks for the fast answer but the problem is still there. I Had the console cleaned. I used external Fans. Is there an other solution?
por
leave the cover off, plug in, turn on, watch the fans.. they might need replacing, or you may need to replace the thermal paste a la RROD repair before you get the RROD.
por
Adicionar a sua resposta
Archer564 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 13
Ao todo: 654
