Ir para o conteúdo principal
Lançado em 16 de setembro de 2016. Modelo 1660, 1778 Disponível como GSM ou CDMA / 32, 128 ou 256 GB / Ouro Rosa, Dourado, Prateado, Preto Mattte e Preto Brilhoso.
2264 Perguntas Visualizar todos
iPhone 7 severe battery drain
Hello, I have a 2 year old iPhone 7 which suffers from severe battery drain, the battery drains from 100% to 0% within 4-7 hours while not in use. The battery health is at 83%, so that shouldn’t be an issue. I’ve tried resetting it multiple times, updating to the latest iOS, turning on airplane mode. Nothing helped. Settings shows no apps using the battery. I found that the iPhone draws 140mA from the battery. I also have a 5 year old iPhone 7 with battery health at 77% and it drains from 100% to 0% in like a week. What could cause it?
Esta é uma boa pergunta?
Pontuação 0
2 comentários
any issues with wifi ?
por
Wifi works just fine. I've tried with airplane mode on, no change.
por
Adicionar um comentário
2 respostas
Solução escolhida
If you got those readings from a DCPS you would defiantly have a board problem. If you are using an USB ammeter to obtain them it would point to a faulty battery.
The first rule in board repair is to rule out parts. From experience an iPhone 7 with battery health at 87 and below will cause this problem.
Esta resposta foi útil?
Pontuação 3
Perhaps one of two things has happened.
1) A malicious program is on your phone draining the battery
or
2) Your battery is faulty, even though the life is at 83% it could just be bad.
You may just want to get a new battery.
Pontuação 0
2 comentários:
I've said, that I've tried resetting it multiple times, so that means malicious program is not the cause, also the battery is perfectly fine. I think you commented without even reading what I've written. The iPhone draws 140mAmps when locked or off, it's shouldn't draw a singe mAmp when fully charged.
por
It appears that you are right. I did not notice that you tested the voltage, forgive me for missing that. So, if that’s the case. The only thing I could think of is to use a testing app to test the iPhone. TestM Hardware is the one I use. But that’s all I can think of. Hope you can fix it.
por
Adicionar a sua resposta
TheTechKing será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 18
Duração total: 378
