Ir para o conteúdo principal
The first generation of the compact sport coupe, the Scion tC.
Why is my RPM too high at lower speeds and car not shifting into third
Got a used engine under 55k mikes installed at auto shop due to a failed piston compression in my previous one. Get the car back a week later told it’s fine to drive. Come to find out that the RPM’s are way too high going a slower speeds. Took it in again and had them check the transmission and they installed a new filter and topped off fluid. Still having same issue but they told me that the car needs to relearn when to shift since but i drove it over 20 miles at various speeds and is doing the same thing. I told them to check the ECU but insisted that it just needed to relearn. What is the issue?
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Save yourself time and headache and take it to a Toyota dealer\shop.
por
Adicionar um comentário
1 resposta
Pergunta mais útil
If it IS the ECU needing to relearn… check this website: https://autoguysland.com/how-long-does-i...
It has helpful information. 20 miles may not be enough for it to fully relearn everything. It can take a bit longer than one would think. If you still think something is definitely wrong then I'd advise taking to a dealership. It could be that your TCM needs flashed.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Christian Agullana será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 25
Ao todo: 404
