Ir para o conteúdo principal
15 inch "Desk Lamp" iMac G4 700MHz M6498 PowerMac 4,2
20 Perguntas Visualizar todos
Will an 800 mhz board fit in a 700 mhz model?
I am in need of a logic board replacement and I am wondering if an 800 mhz logic board will fit or be compatible with my (currently) 700 mhz imac g4 15”, or will i need to just get another 700 mhz board. also, if anyone can, is there a site that has these parts that is low enough in cost.
Thanks!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Yes, you can use the 800 MHz board in place of your 700 MHz.
Did you not try the source I pointed you to?
I’m sure you can also find the part searching Google by the part numbers.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Roman será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 8
Ao todo: 86
