Ir para o conteúdo principal
Broke Touch ID, how to disable it functionally?
I dropped a new iPad Air 4. I broke Touch ID, I don't need it, but the power button began to warm up excessively, turned off Touch ID completely, but still the button warms up. I note that the power button warms up only if you turn off the screen, that is, lock the screen, if the screen is on, it does not warm up, and as soon as I turn off the screen, it starts, and the battery also eats! Is it possible to completely functionally disable Touch ID, or is it possible to physically disable it, but to make the power button work?
Esta é uma boa pergunta?
Pontuação 5
9 comentários:
Hi! I’m having exactly the same issue, have any of you worked it out ? I really don’t want to pay 450 bucks at my Apple Store :/
por
I'm having the same problem, did you find a solution? My battery is draining so fast because of my cracked touch id button :(
por
I haven't solved the problem in any way, but I'm thinking of opening it and physically disconnecting it from the board, I don't know if it will help or not
por
your solution gave me the idea to totally break it, thanks!
por
Well, IPAD Air 5 is my first apple device after ipod touch 4.
In which i was able to change battery and display
And now i have broken IRREPLACEABLE BUTTON WHICH HEATS UP AND DRAINS MY BATTERY?
It was like such a lite hit…
I suppose apple fan will say I should buy pro version with face id.
por
Exibir mais 4 comentários
Adicionar um comentário
2 respostas
Comes complete with aftermarket home button. (Without fingerprint functionality)
https://store.ifixit.co.uk/products/ipad...
Esta resposta foi útil?
Pontuação 0
1 comentário:
We're talking Air 4 here, not regular Ipad 4
por
Go to settings>Touch ID and password>and disable Touch ID
Pontuação 0
Adicionar a sua resposta
Amur Tar será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 27
Ao todo: 1,610
