Ir para o conteúdo principal
A 5ª geração dos smartphones Moto E Play, lançada em julho de 2018. Números de modelo XT1921
Why won't the Microphone work?
My microphone on my Motorola will not work. Whenever I try to call people, they can’t here me.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi,
Try using the phone in loudspeaker mode or insert a set of earphones with a microphone attachment to the headset connector on the phone and check if you can be heard OK when on a call.
If you can be heard then as you say there is a problem with the phone’s internal microphone when using the phone in the normal way on a call.
Use a magnifying glass and a strong light to visually inspect the voice inlet hole, located on the bottom edge of the phone to the right of the charge port, to see if it is blocked with lint etc.
If it appears to be blocked or you’re not sure, do not use a pin or metal probe to try and clear it as you may damage the microphone which is behind the hole. Try using a vacuum cleaner to try and clear it.
If still no good the phone will have to be opened and the microphone checked to find out what’s wrong. Here’s an image taken from the Ifixit Substituição da tela do Motorola Moto E5 Play guide, showing the location of the microphone.
Imagem
(click on image to enlarge)
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Doge Productions será eternamente grato(a).
Visualizações:
Últimas 24 horas: 7
Últimos 7 dias: 14
Últimos 30 dias: 31
Ao todo: 799
