Replacement interior plastic brace/bracket with screw holes for XB12?
My Sony XB12 dropped and upon opening the outer shell you can see that the interior brackets snapped, everything else is okay and fully functional. Now the screws have nothing to screw on to and keep it closed, much less watertight.
Where can I find replacement brackets?
EDIT: both of the screw stems of the bracket, where the battery is attached, are capped and one of the mounting holes from the board bracket is obliterated while the other has three cracks and with any force will also split open.
Esta é uma boa pergunta?
