Ir para o conteúdo principal
A1418 | EMC 2889 | final de 2015 | Intel Core i5 dual-core de 1,6 GHz ou Intel Core i5 quad-core de 2,8 GHz. Lançado em 13 de outubro de 2015.
What does blinking LEDs 1 and 2 mean?
iMac 21.5” does not power up, no chime is heard. I know that LED codes are: LED 1 on= trickle voltage from power supply is detected by logicboard. LED2 on= logic board has detected proper power from the power supply when the computer is turned on.
The problem is BOTH LEDs 1 and 2 are BLINKING (not ON continuously) when I connect the AC power cable to the mains wall socket. What problem does this point to?
Esta é uma boa pergunta?
Pontuação 2
4 comentários:
Can you offer some additional details on what preceded things here.
por
Nothing unusual happened prior to. Thing just suddenly won't turn on.
por
Where is the light coming from?
por
Light comes from the vertically arranged LED array on the logicboard.
por
Adicionar um comentário
1 resposta
What does the other LED’s telling you?
Imagem
Did you try reseating the RAM? Did you replace the RAM you might have a bad SO-DIMM.
Esta resposta foi útil?
Pontuação 0
3 comentários:
The RAM is permanently soldered to the logicboard in this model, and cannot be replaced.
por
Dan, when I press the power button, the 2 other LEDs remain unlit, #1 and #2 LEDs turn off. When I release the power button, LEDs #3 and 4 remain off and #1 and #2 start to blink again.
por
@Bernie - Sorry your right! One of the few iMacs with soldered RAM.
I think your logic board is blown then.
por
Adicionar a sua resposta
Bernie será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 11
Ao todo: 530
