Ir para o conteúdo principal
Modelo A1993. Atualização de 2018 do Mac mini da Apple. As opções de processador incluem Intel Core i3 quad-core de 3,6 GHz, Intel Core i5 de 6 núcleos de 3,0 GHz e processadores Intel Core i7 de 6 núcleos de 3,2 GHz.
Mac Mini 2018 No Power
Hi all, I’ve got a dead Mac Mini. I have confirmed the power supply is not the issue, outputting 12V via 7 pins which is as expected for this model. Something is wrong on the mainboard and I think I’ve identified the faulty component. Looks like an inductor? Plastic is melted on one side of it and it’s close to the power supply connection. Can someone please help me identify the component, I’ll need to source a replacement. Pics attached. It is the component labelled R10 1945.
Thanks!
Imagem
Imagem
@vogelek23 wondering if you can assist? A couple of years ago you helped me identify a couple of components on a 2014 mac mini board. Thanks!
Imagem
Esta é uma boa pergunta?
Pontuação 1
1 comentário
Managed to find a schematic, this is what the component is. Where to source?
por
Adicionar um comentário
1 resposta
Pergunta mais útil
@Charles I'd get the datasheet from places like this and take that data from the electrical characteristics.
Then take this data and check places like Mouser.com Digikey,com, Jameco.com or any other electronic warehouse and see if they can match the original Superworld SSL0705 inductor.
Inductance L ( uH )0.105 ± 20%
Test Freq. 0.25V/1M
DCR (mOhm) 0.46
Irms (A) Max 31
Isat (A) Max 46
Schematics for a Mac Mini? Outstanding find.
Esta resposta foi útil?
Pontuação 1
3 comentários:
Looks like this will do?
https://www.mouser.co.uk/ProductDetail/P...
btw schematic shows .00032 ohms there is a 46 and 32 variant..... 32 is the one to go for I believe.
por
@Charles yes, that looks like it should work
por
Did this ever fix it?
por
Adicionar a sua resposta
Charles será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 17
Ao todo: 737
