2010VW Golf mk6 Instrument cluster board component identification help
Hi Guys,
A bit frustrated, having trouble finding schematics for 2010 vw golf mk6 instrument cluster. Not powering on at all so trying to find fault. Need help identifying some components.
This component has numbers printed on top: R527A and some sort of symbol like a C with lines through it. What is it? How do I find it on Digikey? Photo bellow:
Here is a photo of the whole board:
Trying to follow the pin thats supposed to supply power to it. It seems I am not getting a reading at all in diode mode. There is something wrong along that line. Finding it really hard with no schematics or board-view to help follow it along.
If anyone has any advise or prior repair knowledge of a newer no power instrument cluster repair would be more than appreciated. Am really stuck. Here is a photo of the other side of the board:
Also could not find this mosfet?? Marking on top is 24C64WQ K022P
Like I said main problem is no power at all
Any help? Thanks everyone ;) ( would be so much easier with board-view)
*****UPDATE:
This is really a mindf**ck
WOB/10 BCP56 Does this have anything to do with voltage going into the unit?
ok so compared known good with bad.
Diode mode
Good / old
Pin 1 - 0.622v - 0.626v
Pin 2 - 1.154v - 1.160v
Pin 3 - 0.034v - 0.034v
Pin 4 - 1.153v - 1.158v
Continuity Mode
Good / old
Pin 1 - OL - OL
Pin 2 - OL - OL
Pin 3 - 22.5Ohms - 22.4Ohms
Pin 4 - OL - OL
This above is some sort of diode
Diode mode
bottom
Good/R531A / old/R527A Does this have anything to do with voltage going into the unit? Could this be why it’s not powering on?
Good -/ Old
1.598v - 2.690v
top
OL - OL
Continuity mode
Good/R531A old/R527A
TOP
OL BEEP - OL NO BEEP
4275G RB 032 Does this control voltage going into the unit?
Continuity Mode
Good / old
Pin 1 - OL - OL
Pin 2 - OL - OL
Pin 3 - 0.6 Ohms Beep - 1.5 Ohms Beep
Pin 4 - OL - OL
Pin 5 - OL - OL
Pin 6 - 0.6 Ohms Beep - 1.5 Ohms Beep
Diode Mode
Good / old
Pin 1 - 1.6v - 2.693v (WHY IS THERE SUCH A DIFFERENCE HERE????)
Pin 2 -0.673v - 0.671v
Pin 3 - 0.002v - 0.002v
Pin 4 - 0.647v - 0.645v
Pin 5 - 0.447v - 0.656v
Pin 6 - 0.002v - 0.002v
Ohms
Good -/ Old
Pin OL - OL
Pin OL - OL
Pin 3 - 0.7 Ohms - 0.5 Ohms
Pin 4 - OL - OL
Pin 5 - OL - OL
Pin 6 - 0.7 Ohms - 0.7 Ohms
42765G RC 027 Does this control voltage going into the unit?
Continuity Mode
Good / old
Pin 1 - OL - OL
Pin 2 - OL - OL
Pin 3 - 0.5 Ohms - 1.4 Ohms (WHY SUCH A DIFFERENCE HERE?????)
Pin 4 - OL - OL
Pin 5 - OL - OL
Pin 6 - 0.5 Ohms - 1.4 Ohms (WHY SUCH A DIFFERENCE HERE?????)
Diode Mode
Good / old
Pin 2 -1.414v - 2.181v (WHY IS THERE SUCH A DIFFERENCE HERE????)
Pin 4 - OL - OL
Pin 5 - 0.538v - 0.580v
Pin 6 - 0.001v - 0.002v
Ohms
Good - / Old
Pin OL - OL
Pin OL - OL
Pin 3 - 0.8 Ohms - 0.4 Ohms
Pin 4 - OL - OL
Pin 5 - OL - OL
Pin 6 - 0.8 Ohms - 0.4 Ohms
I think I’m gonna go jump off the balcony pppffffttttt :"-(
Esta é uma boa pergunta?
It is hard without schematics and board view. It looks like 24C64WQ K022P is actually some sort of EEPROM It doesn’t look like a Fett.
por Chris Stables
hey Chris, Thanks mate. Yeah I know its driving me crazy. I can't believe there is no schematics for it on google
por Tommy Duris
@Tommy Duris
There won't be a schematic for the cluster in the service manual but it should show where the power comes into the cluster in the electrical wiring diagrams for the vehicle, which may be a start.
I didn't check because it is a 428MB download.
Cheers.
por jayeff
Hi Jayeff, Yeah I did find that and know that pin 32 is supposed to supply power to the instrument cluster but multimeter shows OL on pin 32, so I know there is a problem on that line but am having trouble following it between both sides. Boardview would of been excellent for that. Would allow me to repair it very quickly, now not so much.
por Tommy Duris
@Tommy Duris
So there is no power getting to the cluster board from wherever it comes from rather than a problem on the board itself?
Doesn't the repair manual show where the power comes from e.g. a control module or a fuse perhaps?
por jayeff
Exibir mais 22 comentários
