Power fuse. Where is it?
I’m trying to find the Power fuse im our Cafeo Solo.
Where is it placed? And what type of fuse is it?
Esta é uma boa pergunta?
All heating appliances must have thermal fuses to prevent a fire. They’re in line with the power inside the case clipped to the heating element section.
One version looks like a 3/16” diameter x 1/2” cylinder with an epoxy tapered plug in one end. One wire is attached at each end.
Another common version is a 1/2” diameter x 3/8” high can with 2 mounting tabs and 2 spade lugs for the wires.
I hope it has the rating marked, usually in Centigrade, otherwise you’ll have to find it. Thermal fuses are made in a wide variety of temperature ratings - it’s dangerous to guess it.
Esta resposta foi útil?
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 31
Ao todo: 662
1 comentário
@VauWeh any idea about this? @jannegus ,he is the coffee machine guru and wrote the guides for this model. The @ should notify him of your question. Let's see what happens
por oldturkey03
