Can I change my 84 Toyota pickup from a mechanical fuel pump to electr
I had to change my fuel tank in my 84 Toyota pickup can I change to a electric fuel pump
Esta é uma boa pergunta?
ann bourliea what engine is it and right now it has a mechanical fuel pump? The tank you replaced is from what year? There should not be a pump in the tank but we need to know more. Yes, you an convert to an electric pump just mounted externally somewhere on the back of the frame and place a filter before the pump. You can even leave the old mechanical pump on the block. We do need more details so as to find out what issues you foresee.
Esta resposta foi útil?
Yes just bypass the mechanical pump and drop the electricalone in the tank
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 16
Duração total: 322
