Ir para o conteúdo principal
The Xbox One X (Model 1787) is Microsoft's high-powered game console, succeeding the Xbox One S. The Xbox One X was released on November 7th, 2017.
20 Perguntas Visualizar todos
Graphics memory DDR5 defective
Hello everyone.
On my Xbox one X I have one or more defective DDR5 memories.
I have no graphic errors in the menu or in the apps.
Also in games such as Biomutant, Crash Bandicoot 4 I have no graphics errors.
But when I start forza horizon 4 I already have graphics errors in the menu. Wrong colors etc.
A defective DDR5 RAM is being accessed.
My question is there a way to find out which ram is defective?
Wouldn't like to swap all 12.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
Just replace all 12. Modern consoles are designed to PREVENT testing of the RAM chips once it leaves the factory, this is for software security.
You can test the chips one by one, however the extra labor time is not worth it, also reheating the board 12 times creates more problems than it solves.
Esta resposta foi útil?
Pontuação 1
If you want to find the defective one, its a good idea to remove ram and boot back up until the error is resolved. The first one to appear defective will be your defective one. Obviously keep going to make sure there arent multiple modules defective. Hopefully this helps. :)
Pontuação 0
Adicionar a sua resposta
Daniel será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 3
Ao todo: 105
