Ir para o conteúdo principal
A Oster Expressbake CKSTBRTW20 é uma máquina de fazer pão elétrica lançada em 2009, capaz de preparar 0,9 kg de pão em menos de uma hora utilizando o recurso Expressbake.
Device has stopped mixing.
Hello! I recently picked this up at a thrift shop since I have always wanted to try one. I’ve used it 7 or 8 times and the last couple times the paddle would stop spinning to mix the ingredients. I thought it was due to gunk on the paddle or the inner container wasn’t inserted properly. This last time it mixed maybe two times and then would have an audible “click” sound instead of turning the paddle. Does anyone know how to fix the motor or attachment?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Andra Hutton could be the motor as well as the electronics. Let’s see what it looks like I suggest you start by disassembling it using something like this guide Substituição da câmara interna da Oster Expressbake CKSTBRTW20
Make sure that mechanically it all looks okay. You can always post some of your devices images, with your QUESTION, while you do the work. that way we can see what you see and possibly assist you further. Let us know if you find some oddities etc. Adicionar imagens a uma pergunta já existente
Imagem de iFixit
Guia
Nível de dificuldade:
Muito fácil
2 - 5 minutes
Imagem de Oster Expressbake CKSTBRTW20 Câmara interna
Guia
Moderado
20 minutes
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Andra Hutton será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 9
Últimos 30 dias: 38
Ao todo: 499
