Why only one LED on Ethernet port is steady ON? There is no connection
Hello everyone,
I have a motherboard MI970 which has two ethernet port, one Intel 82579LM and one 82583V.
The 82583V port was connected to a raspberry Pi. I have noticed that the connection was disconnected and a yellow LED on it is steady on, it doesn't matter if a cable is connected or not.
After I have noticed this issue, I have checked the device manager and the driver under Network Adapter was with a yellow exclamation mark, so I have tried to unistall and reinstall it but disappeared totally. I have checked under hidden devices, and wasn't there.
Also, I have tried restart the system and turned it off for a while. Nothing changed. Since the system is on the LED of the port is ON and is not working.
Also, I have tried to install the driver manually but it didn't allow me to install.
Is there any solution for this issue?
Also, if I cannot use the port and is knocked, can the motherboard be used? I meant it cannot cause any more issues on other parts?
I would appreciate if you could give me some advice.
Thanks in advance,
Milad
Esta é uma boa pergunta?
2 comentários
What is the exact make and model number of the motherboard?
por mike
Thanks a lot @aactech
Intel MI970VF
por Milad Bagheri
