Ir para o conteúdo principal
The Lincoln model K2513-1 is an electric flux-cored welder designed for basic wire welding projects and repairs. It can output between 30 Amps and 125 Amps at a rate of 50 - 500 inches of wire per minute.
1 Perguntas Visualizar todos
I want to buy Lincoln 180 welding machine
I am thinking to buy a mig welder from the Lincoln brand. It could be this Lincoln 180 MIG welder. What is the difference between these two model? I am thinking to buy this model: https://bestmigwelders.org/lincoln/180-m... . What do you think about this Lincoln model.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi @rswebss
Here are the product sheets for both models.
A quick read through indicates that the K2513-1 is a smaller capacity unit than a MIG 180C (model #K2668)
By this I mean that the output current is only 30A -125A as opposed to 20A-180A and the cored wire size is also smaller i.e. 0.6-0.9mm as opposed to 0.9 - 1.1mm. There are other differences as well but I haven’t read it all to find out.
It may depend on what you want to do with it.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Mr Roswobs será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 6
Duração total: 197
