Cracked bezel - do I need to fix it?
Hi I had something the crease of my screen and I closed it and it cracked. Does this need to be fixed right away or even at all?? If so how do I go about it???
Esta é uma boa pergunta?
You are so lucky your display still works. It is not repairable, you have to replace the whole display unit and the cost, $500.00 + )if you can find one) will make you want to throw up. Live with it if you can.
Esta resposta foi útil?
Technically the nameplate can be replaced, but it's not an easy process.
The bottom bar is probably repairable, at least for MBP, not sure about the Air.
This is consumer electronics, there is no “need” to, you just “want” to.
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Duração total: 133
