Ir para o conteúdo principal
Released September 24th, Apple's 2021 flagship smartphone features a 6.1" ProMotion OLED display, a new triple-lens rear camera system, and 5G. Successor to the iPhone 12 Pro.
57 Perguntas Visualizar todos
Is the screen replaceable on the iPhone 13 pro?
I heard that if you replace the screen on the iPhone 13 that Face ID won’t work anymore, is it true?
Esta é uma boa pergunta?
Pontuação 3
4 comentários
Yes at this time
por
it is true, only apple can pair the new components. You and third parties can not.
por
iPhone 13 Pro- Replacing the screen with an original apple screen taken off a Donor phone will lose or retain Face I.D.?
por
@malcolm34057 There was a limited time period in which iOS was killing Face ID when the screen's serial number didn't match that of the phone, but after much public outrage at such a tactic, they relented and removed that matching requirement from the latest iOS versions.
As long as you make sure to update your iOS, Face ID will still work after replacing the screen. You will, however, get a "non-genuine" part pop-up warning for about a week though, whether it's a genuine Apple screen or not unless you transfer the IC that @primalphoenix was talking about in their answer.
por
Adicionar um comentário
4 respostas
Solução escolhida
Yes at the moment this is true. Even if you transfer the components across from the screens it will still not work. The front camera will not work properly either.
Hopefully apple might fix this in the next software update.
Esta resposta foi útil?
Pontuação 2
The only way to get Face ID back after a screen replacement on the 13 is to transfer one of the ICs on the back of the screen by micro-soldering.
Edit: Apple is no longer disabling Face ID after screen replacements on the iPhone 13 series
Pontuação 2
This post is not more relevant, since Apple changed the software. Face-ID won't be disabled after a screen replacement.
Pontuação 0
Currently, on the iPhone 13 Series, when replacing the new screen, you can still use Face ID as usual. However, the technician will have to move the old display IC to the new screen. This helps the iPhone after being replaced without the "unknown components screen" message.
Although it is possible to use Face ID normally, the current iPhone 13 series after replacing the screen will not have the TrueTone function as on the old screen.
You can check out more of my posts here: Thay màn hình iPhone 13 Pro Max
Pontuação 0
Adicionar a sua resposta
Nathan será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 12
Últimos 30 dias: 37
Duração total: 1,920
