Ir para o conteúdo principal
Repair information for the things you might find in around the yard or patio, including BBQ grills and equipment, gardening tools, and weather stations.
20 Perguntas Visualizar todos
Garden shredder does not stay on
I have a garden shredder al-ko h2200. The day i bought it, the guy who was selling it tested it on my eyes and everything went great. Next day i turn it on in my place and it doesn't stay on. There is this switch that is supposed to stay on but it doesn’t and i have to keep holding it to have it keep working which of course is undoable. I opened it and cleaned several times, there is not much to brake or change there, i have no idea what could be the issue.
Please help!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Maja Borkowska either you have a bad rotary switch or you have something blocking the blade. Double-check everything.
Complete manual here AL KO H2200 Shredder
Esta resposta foi útil?
Pontuação 2
2 comentários:
The blades are running fine, so i suppose it must be a bad rotary switch. How can that be fixed? Do you think it's some electrical problem inside?
por
It says something about a safety switch in case of overload and I wonder if that is what causes this. Ultimately time to take a look at the switch and possibly replace it with a new one. That at least will not be too complicated or expensive. Any good rotary switch should work for that.
por
Adicionar a sua resposta
Maja Borkowska será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 16
Duração total: 474
