Back Panel Removal on a Sony XBR65X800h
This is a unique set in regards to the back panel. It is a full rear panel, top to bottom. Minimal screws on the bottom and none on the top similar to Samsung’s screwless back panel. How does this come off? Does it pry off like the Samsung TV’s? To be clear this is not the half back panel that the slim Sony’s have. This is a full back panel. Unique to this size of tv. The image above is the actual set.
I removed 5 screws. 4 where the wall mount would screw into the set and one by the power plug.
Looks like the bottom is held in with plastic clips which I have released. The sides and top all seem to fit into the front frame all the way around so no way of hitting the bottom to have it slide up. Maybe the front frame has to come off first? The rear panel is connected to the front panel frame.
Esta é uma boa pergunta?
