Ir para o conteúdo principal
The Razer Blade Stealth is a gaming laptop with a 13.3 inch wide screen. The laptop features 16 GB of RAM and an Intel Core i7 CPU. It comes in Space Grey and Mercury White.
3 Perguntas Visualizar todos
New battery only works while plugged in
I just replaced my battery in my razer blade stealth and it works fine while plugged in but says charging and stuck at 97% and when I unplug it it turns off immediately and won't turn on while unplugged. The battery is brand new. The old one was fairly bloated.
Esta é uma boa pergunta?
Pontuação 3
3 comentários
does the laptop power on without a battery?
por
@logixal yea it will power on without the battery connected
por
Exact same problem!
por
Adicionar um comentário
1 resposta
Pergunta mais útil
@riveteer I am certain you double-checked your work and made sure that your connectors are all properly seated and that there are no issues like bend pins etc. with those. I would contact the seller and replace the battery once more just to rule it out as the culprit.
Esta resposta foi útil?
Pontuação 1
1 comentário:
Yea thanks. I did look around more today and was looking at the connector for the original battery and the one I bought from ifixit had a poor connector. I bought another and plan on returning the one I got. Thanks
por
Adicionar a sua resposta
Jack Kuckhahn será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 6
Ao todo: 788
