Ir para o conteúdo principal
Model A1347. Released on October 23, 2012. Core i5 or Core i7 Processor. Apple Fusion Drive.
Dual Hard Drive Cable Kit Question
I am experiencing the question mark folder error after few hours of on-time. Internet posts point to the hard drive cable being the issue which led me to here.
Instead of buying this line cable from this link: Mac mini A1347 (Mid 2011-Late 2014) Upper SATA Cable
Would it be fine to order this kit? Mac mini Dual Drive Kit
Imagem de All the hardware needed to a second hard drive to your 2011 or 2012 Mac mini.
Produto
$26.99
Imagem de Replace a malfunctioning or torn SATA hard drive cable for a Mac mini. In a 2011 or 2012 model Mac mini configured as a dual hard drive server this cable fits the second or upper hard drive. In a 2014 model Mac mini this cable fits the single hard drive.
Produto
$19.99
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
It’s a matter of which bay the boot drive is in and what you have for drives.
Update (09/13/2021)
@dennyho93 - Best to check as Apple did both ways ;-{
Follow this guide to Step 5 Mac mini Late 2012 Logic Board Replacement You just need to lift the fan up to check the cable connections
BTW - Here’s the other cable: Mac mini A1347 (Mid 2011-Late 2012) Lower SATA Cable
The kit offers the needed tool to open the system, that U shaped tool, needed drivers & screws.
Imagem de Replace a malfunctioning or torn SATA hard drive cable for the lower hard drive slot.
Produto
$19.99
Esta resposta foi útil?
Pontuação 1
1 comentário:
I assume it's an entirely stock late 2012 Mac mini, so whatever their stock configuration was
por
Adicionar a sua resposta
Denny Ho será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 9
Ao todo: 126
