Ir para o conteúdo principal
Fans won't come on now
Xbox360 used to have three rings now gone, I know have two rings. It can't be getting hot because the two ring come up straight away and the fans don,t turn on and the disk tray won,t open either. Help
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Solução escolhida
Kent, check on here for a good explanation of the error codes and how to obtain more information from your console. The error itself can be caused when the CPU or the GPU are overheating as well as a bad solder connection of the Ram chip. I guess the only way to fix it would be to reflow the board either by a professional or you could try this. The only other thing I can think of is to use the RROD kit from here. Hope this helps, good luck.
Imagem de Xbox 360 Red Ring of Death Fix Kit
Guia
Nível de dificuldade:
Difícil
45 minutes - 1 hour
Imagem de Xbox 360
Guia
Reflowing Xbox 360 Motherboard
Difícil
1 - 3 hours
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Kent será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 197
