Ir para o conteúdo principal
Lançado em abril de 2019. Número do modelo: SP315-51-757C. Laptop com tela tátil totalmente rotativo da Acer.
Why is my touchpad not working?
Today I turned on my laptop (Windows 10) and for some reason I couldn’t see my cursor anywhere and when I moved my touchpad nothing would move. When I plug in my USB mouse, the cursor comes up and I can use my mouse to move it, but the touchpad still isnt responding. I made sure that the touchpad setting is on, restarted my laptop and when I tried to update the driver for the touchpad, nothing was there apart from a few mouse settings. Ive tried the Fn buttons as well so I dont know what the next step from here is.
Esta é uma boa pergunta?
Pontuação 1
5 comentários:
how did you treat the touchpad ?
por
if its not software problems then it maybe hardware problem
por
@lockxh Pretty well I think. It was working completely fine yesterday too and it just stopped next morning.
por
you could refer to one of the guide to opening your computer and then maybe inspect it with maybe a magnifier and then find maybe anything that does not look right in a computer
por
@lockxh Okay, I might do that as last resort. Thanks
por
Adicionar um comentário
1 resposta
I had the exact same issue with a dell latitude 5480 where the trackpad I had tried everything I knew and eventually I had to reach out to dell for their warranty repair and they said all they did was reinstall windows 10. So I recommend backing up as much as you can and trying that
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Kevin Age será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 10
Ao todo: 699
