Ir para o conteúdo principal
TI-84 Plus calculator support.
35 Perguntas Visualizar todos
Been charging for over 8 hours, light indicates still charging
So absolute disclaimer; This calculator worked fine in high school for me. However, it’s been around 4 years and as such the calculator has been sitting in a box unused for that time. I’m trying to see if it still works to sell it. At the time I’m posting this it’s been charging with the amber light indicator for 21 hours. Over this time I’ve tried turning it on multiple times with no luck. Should I let it continue to charge until I get a green light or is something wrong?
Esta pergunta é pertinente?
Pontuação 0
1 dos comentários
It's important to let us know exactly which TI-84 Plus you have. What is the calculator's full name at the very top?
por
Adicionar um comentário
1 Resposta
Solução escolhida
The TI-84 Plus uses 4 replaceable AA batteries. Turn the calculator on its back and remove the battery cover, then remove and replace the 4 AA batteries. If there is corrosion in the battery compartment, use a paper towel with vinegar to clean it off. If you’re having trouble, you can follow the teardown guide up to step 5.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Jodie Lynn será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 3
Duração total: 51
