Kobo - Replacement button
I’m trying to find a replacement button for my Kobo Ereader, the rubber went brittle and crumpled :(
Esta é uma boa pergunta?
Most of them have very generic buttons found in many devices, but usually requires soldering to replace them. Heat station and an iron would be requite usually.
If it’s the type of button I’m thinking about you may find some on digikey or amazon sometimes.
Can you send a picture of the button?
I hope this helps
Esta resposta foi útil?
Did you find a solution? I have a white Kobo 2009 (no wifi). The rubberized square button on the front has deteriorated and crumpled too.
https://kolico.ca/tmp/kobo1-IMG_20210916...
A closer look:
https://kolico.ca/tmp/kobo2-IMG_20210916...
:( This is a sad time for me.
Can anyone think of a suitable hack?
I have the same problem, would love to hear a solution
Can we not get a replacement button or do we thrash the economy reader?
If it's the external button in the case, you might have some success making a replacement out of hot glue and / or a stiff bit of plastic - that what I'm trying
Why does this say solved when it clearly isnt?
Same issue, same side of the button even.
I did find this, though it's not a soft button, but it's certainly an option? Haven't tried it yet though, need to talk to a friend with a printer.
https://www.reddit.com/r/functionalprint...
Últimas 24 horas: 3
Últimos 7 dias: 31
Últimos 30 dias: 125
Ao todo: 5,587
2 comentários
What model is your Kobo e-reader?
por Andrew S
It's a 2010 Kobo WiFi
por Caitlyn Patterson
