Ir para o conteúdo principal
Smartphone topo de linha da Huawei lançado em abril de 2019. Com uma tela OLED FHD+ de 6,47", sensor de impressão digital integrado na tela, câmera principal de 40 MP, câmera teleobjetiva de 8 MP e uma nova tecnologia de alto-falante auricular. Modelos VOG-L29 e VOG-L09.
No audio from bottom microphone
Hi all, I realised my P30 Pro’s bottom microphone stopped working. All apps that use this (Shazam, Google) pick up no sound from it. If I’m on a call, i have to wait between 5-10 seconds (which I think is when the top mic kicks in), then person can hear me. I have factory reset, cleared all caches but no luck so going to attempt changing the microphone/ SIM board. Has anyone done this before with success? On eb@y there are some boards that have this little silver IC in the middle of the board, and some don’t (this is on the opposites side of the SIM slot). Does anyone know what that is?
Esta é uma boa pergunta?
Pontuação 3
1 comentário
I changed bottom board with microphone and still doesnt work
por
Adicionar um comentário
3 respostas
Pergunta mais útil
Yes same problem I had. Changing the sim/mic board will fix problem.
Esta resposta foi útil?
Pontuação 2
You're on the right track.
This is exactly what the p30 pro does when the bottom mic stops working.
The mic is soldered on a small pcb that has the simtray on it.
Do inspect your part before installing it because I’ve seen alot of them being very badly refurbished for resale where the IC and stucked there with glue instead of being soldered to the board. It might be hard to see without a microscope, but I just want to let you know that that is a common practice with the P30 pro sim/mic board for some reason.
I hope this helps.
Pontuação 1
3 comentários:
Thank you for your response. There are 2 ICs on that board, one close to the mic port and one in the centre of the board. Do you know which one it is?
por
I'm sorry, but I'm not sure I understand your question.
Just look at your board to see if the IC location matches what you are buying.
I think there maybe 2 version or so. That is because some countries uses dual sim, and some only uses single sim.
por
I get shasham and g-assistant to work, by letting a voice recorder run in the background
por
Pontuação 1
Adicionar a sua resposta
theun4given1 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 32
Ao todo: 5,800
