Ir para o conteúdo principal
A Canon EOS 60D é uma câmera DSLR (digital single-lens reflex) de 18 MP com uma tela LCD articulada. A câmera foi lançada em agosto de 2010 e é identificada pela inscrição EOS 60D na parte frontal da câmera.
Canon EOS60D USB Interface Board Replacement.
My Canon EOS60D was on a tripod with USB cable in place. Tripod was knocked over and camera landed on the Port side, meaning that the USB plug hit the floor first. Since then the USB connection has not worked although all other camera functions are fine including HDMI interface and remote trigger.
Is it possible to replace the USB interface board and if so, how? I’ve looked at your guides and none go as far as accessing the USB board.
Thanks in advance
Harry Watson
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
1 resposta
Solução escolhida
Hello!
Thankfully (since cameras are so pricey) they are generally repairable. However, parts can be difficult to find, especially for a camera of this age. Have you tried contacting either Canon support, or a local camera store? They will likely have parts, or be able to repair the board themselves. If they cannot, you could try to solder a new USB connector to the PCB. In the meantime (or if you determine it isn’t possible, too expensive, or too risky to try and fix the USB) try removing your SD card and read the data off of it.
Esta resposta foi útil?
Pontuação 1
1 comentário:
All this is good advice. Thanks for answering.
por
Adicionar a sua resposta
Harry Watson será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Ao todo: 385
