Ir para o conteúdo principal
Repair information for the Fitbit Sense. A smartwatch with GPS tracker, health and fitness sensors.
Will the speaker and mic still work if I seal the ports with silicone?
While cleaning the speaker area I think I may have damaged the screen covering the speaker compromising the water resistance. If I were to seal the port where the speaker is, and I think the mic is right next to it, would the mic and speaker still work or would the silicone create a barrier that sound will not go through?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
the silicon will definitely have a negative effect. If they DO still work it will be extremely muffled and no one will be able to understand what you say. I would recommend against sealing the ports for those. Renders them basically useless.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Michael Gieser será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 14
Ao todo: 340
